Clients will drop off of WLAN at steady intervals
justinfvoeller
I have two 2006 series WLC's and 5 ap's on both. I have a WLAN for public use that has only web authentication for security. (This WLAN has internet only, nothing else. Its used for testing.) When users authenticate, everything works for about an hour, then they drop and it takes 10-15 minutes to come back up. Then their good for about another hour.
WHAT IVE DONE:
--There is no QoS running on the the open WLAN
--Changed the client roaming profile:
Minimum RSSI -- -85
Hysteresis -- 4
Scan Threshold -- -72
Transition Time -- 1
Is there anything you guys can help me with? Thanks in advance!
Scott Fella
If the infrastructure is not the issue, try changeing the value on the idle timeout (located on the Controller | General tab) or the session timeout on the WLAN SSID.
-Scott
What should I change these values to?
Try setting it to 28800. That would be 8 hours.
-Scott
Scott Fella
what code are you running.
-Scott
