cllients always connect and disconnec
Mahmoud
we have one ssid and 5 APs at the same floor, we have lot of complains related to clients always disconnect from AP and rejoin to the other AP every few minutes and every time it re authenticate again which affect his connectivity
WLC is 5508
AP is 1832i
any advice ?
marce1000
           - What software version is  the 5508 running ?
 M.
Software Version8.5.161.0
Software is fairly current, but there would be some newer 8.5.x releases.
Do you have Client Band Select or Client Load Balancing features active? Those could cause the described issues and don't offer many benefits today. I would disable them. Check the SSID configuration - Advanced for this.
 - Recommended release for the 5508 is 8.5.171.0  - You can also have a sanity check of the controller configuration with :
                                 https://cway.cisco.com/tools/WirelessAnalyzer/
  M.
