Close management ports on wireless controller
sarat1317
Level 3
Level 3
Hello
I see ports 22,80,443,444,16113 are opened on anchor wireless LAN controller and would like to close these ports from the wireless network. Can someone please advise if this is possible and if there are any concerns closing these ports.
Thank you
Sarat
Ric Beeching
Level 11
Level 11
You can use CPU ACLs to lock down the management interface however be very careful as applying one could leave you with no access to your interface:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-6/configuration-guide/b_cg76/b_cg76_chapter_0110101.html#ID2597
Depending on whether you are using the Service Port for management then that interface will need to have ports 22 and 443 open for secure access. You can probably disable 80 by disabling http access to the management interface.
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/113344-cuwn-ppm.html
Please rate helpful / correct posts
