Hide SSID 1832i
eltomaltdcyprusoffice
Community Member
Hello i have the Cisco Aironet 1832i Model (1830 series).
I will like to know how to non-broadcast the SSID from the 2 wlan i have created (the main and the quest SSID)
Please let me know the commands that i need to configure through SSH as the OS of Cisco is different from other  type of Aironets.
Ric Beeching
Level 11
Level 11
Should be same as this if you can access it via the CLI (SSH/Telnet):
https://supportforums.cisco.com/discussion/12947811/cisco-aironet-1830-disable-ssid-broadcast
From the CLI is the following command available:
config wlan broadcast-ssid disable <wlan id> where wlan id is the number of your wlan. If unsure of that, do a show wlan summary which should give you that info I hope.
Please rate helpful / correct posts
Ric Beeching
Level 11
Level 11
mohanak
Disable unwanted WLANs by entering the following command:
(Cisco Controller) >config wlan disable wlan-id
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-1/mobility_express/b_Mobility_Express_Deployment_guide.pdf
