CNA Spaces and Centrak
R Tillman
I inherited a DNA Spaces deployment that has two collectors onsite and an a connection into the Centrak ecosystem.
- I am being asked to add another Centrak server into Spaces.
- I cannot find any documentation on how to do this. Can someone point me to some documentation on how this works and how to add another server?
Rich R
Suggest to contact Centrak support directly - they should be able to tell you how to setup their product.
https://centrak.com/support
Thank you for the response. I figured out the following by working with the Centrak folks.
1. Centrak needs to add the new Centrak server to their system
2. In Spaces, I had to go into the ecosystem settings to add a new site. This new site was selected from a drop down that Centrak had to add on their side.
3. In Spaces, select the floors to add to the new site.
   - I had to select every single floor, it was a few hundred for me. The system wouldn't allow me to check the box next to the building to include the entire building. THIS NEEDS TO BE IMPROVED.
Thank you
Prince.O
To integrate partner apps into DNA spaces, you can do so via this configuration guide below:
https://www.cisco.com/c/en/us/td/docs/wireless/spaces/config-guide/ciscospaces-configuration-guide/m-partner-app-management.html
