Upgrade Cisco AP Using TFTP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-21-2023 11:43 PM
I have an Cisco® Business 240AC Access Point
Part Number | CBW240AC-x |
it's has frimware issue the light still red
and it disapper from the controller
is there any way to upload new frimware using TFTP
- Labels:
Other Wireless Topics
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-22-2023 12:09 AM
M.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-22-2023 01:51 AM - edited 05-22-2023 01:52 AM
as i said before
the ap didnot appear in the controller and it's has a frimware issue the light of the ap is solid red
i want the manual frimware update with out the controller
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-22-2023 02:00 AM
- These APs don't use a controller ,
M.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-22-2023 04:29 AM
i have another AP works as a controller and many AP's that have been connected to that controller
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-22-2023 04:48 AM
- That's probably a mesh network ; you still have to use the mentioned procedure for upgrading the particular AP locally ,
M.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-22-2023 06:43 AM
Try to factory reset the AP first. It is a simple procedure and may fix the problem.
Go to "Reset to Factory Settings Using an Open Paperclip"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-22-2023 08:18 AM
Have you checked this doc?
https://www.cisco.com/c/en/us/support/docs/smb/wireless/CB-Wireless-Mesh/kmgmt-2322-flashing-red-LED-pattern-day-zero-setup-CBW.html
Please click Helpful if this post helped you and Select as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's and TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's, Best Practices for 9800 WLC's and Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
