Command for association and disassociation between APs and Bridge mode.
Rafael Santos
I have an AP AIR-BR1310G-A-K9 model and when I do the "show dot11 associations" command I can see the other APs associated with it that is in Bridge mode.
I would like to know what command I can execute on my AP in Bridge mode to force a disassociation and then force a new association between the bridge and the other AP.
Thanks in advance.
Rafael Santos
johnd2310
Level 8
Level 8
Have you tried the following command:
clear dot11 client H.H.H
where H.H.H is the mac address of the client
John
**Please rate posts you find helpful**
johnd2310
Level 8
Level 8
John
To remove a client association use:
clear dot11 client <Mac address in format of 0011.2233.4455>
it will deauthenticate the client
Or you can use:
clear int dot11radio0/ dot11radio1
to reset the radio
Useful autonomous CLI commands here:
http://www.my80211.com/cisco-auton-cli-commands/
*****Help out other by using the rating system and marking answered questions as "Answered"*****
