Communication between : AP and WLAN controller
bapatsubodh
Level 7
Level 7
The communication between AP and WLAN Controller is ( Data and Control ) UDP.
Source port 1024 and destination port 12222 and 12223. Actually which device listen to which port or both should listen as control and data can be generated from both the devices.
How does the user ( wireless client) traffic is switched - if user traffic is a TCP traffic. It will be sent to WLANC and then WLANC forwards it to respective VLAN or default gateway ( depending upon the destination in the packet ).
Please explain / share the experience.
any link on cisco.com
Thanka in advance
Subodh
Leo Laohoo
"the LWAPP Control and Data messages are encapsulated in UDP packets that are carried over the IP network. The only requirement is established IP connectivity between the access points and the WLC. The LWAPP tunnel uses the access point's IP address and the WLC's AP Manager interface IP address as endpoints. The AP Manager interface is explained in further detail in the
implementation section. On the access point side, both LWAPP Control and Data messages use an ephemeral port that is derived from a hash of the access point MAC address as the UDP port. On the WLC side, LWAPP Data messages always use UDP port 12222. On the WLC side, LWAPP Control messages always use UDP port 12223.
The mechanics and sequencing of Layer 3 LWAPP are similar to Layer 2 LWAPP except that the packets are carried in UDP packets instead of being encapsulated in Ethernet frames."
Taken from "Cisco 440X Series Wireless LAN Controllers Deployment Guide"
