Compatibility
mwassawa1
Community Member
I am using a cisco controller AIR-CT5508-K9   which supports the indoor 1242 access points. I want to purchase indoor access points as I understand that the 1242 series Access Points are coming to end off life. Kindly advise on which other model I can purchase.
mpathira
Community Member
Supported Access Points are based on the software version of the WLC, and not the WLC model. If the WLC is running version 8.0.120.0, AP-1250 would be one of your choice.
thanks Mpathira,
The Software version of the WLC is 7.0.98.0 . will it still work with the 1250-AP?
1242 AP last support is 8.0.x.
I will say either use 2602 or 2702 AP, but these AP need minimum 7.2.110.0 and 7.6.120.0 respectively.
Check here for more compatibility information: http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Don't forget to rate helpful posts
mohanak
Refer the link for Replacement product for 1242 : http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7900-series/end_of_life_notice_c51-726425.html
End of Service Contract Renewal Date:
HW
The last date to extend or renew a service contract for the product.
October 21, 2017
Last Date of Support:
HW
The last date to receive applicable service and support for the product as entitled by active service contracts or by warranty terms and conditions. After this date, all support services for the product are unavailable, and the product becomes obsolete.
July 31, 2018
