Bookmark
Subscribe
1455
Compatible APs for Cisco WLC 2504
Douglas Barker
Is the cisco wlc 2504 compatible with the AIR-CAP-3602l and if so what firmware would i need to be running on the WLC ? My firm rushed out and bought a mesh solution without doing their homework
kcnajaf
Level 7
Level 7
Hi Doug,
Data sheet for 3602 access point shows it support 2500 series WLC. Please refer to the link below.
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps11983/data_sheet_c78-686782.html
You may need firmware version above 7.2 to support 3602.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Hope that  helps
Najaf
Please rate when applicable or helpful !!!
kcnajaf
Level 7
Level 7
Hi Doug,
Hope that  helps
Najaf
art-barrera
Really you should look at it more from a question of what software version is compatible for the controller.  Once that is answered, the software version will have it's own compatibility matrix.  In addition, release notes detailed for every release will specify any FUS required by controller platform.  In other words, if I have a 2500 series controller running 7.0.x code, it will not support a 3600 ap deployment. Thx! //art
