Conectivity with mobile equipment
admin_2
Level 3
Level 3
We have great coverage with the use of the 350 bridges, but we are unable to keep a wireless connection with our mobile equipment. Our mobile equipment averages about 30 mph and after about 10 minutes our radios go into limbo and we have to manually reset them. Is there any solution?
wong34539
Level 6
Level 6
We have a number of sites using 350 bridges in mobile solutions, at speeds over 60 mph, so I am not sure why this is happening. The common things to look for are latest firmware loads, verify good connection between mobile and root bridges and check the logs for association data (to verify the mobile non-root is not bouncing back and forth between root bridges).
