Configuration Cisco AP 2600(AIR-CAP2602I-E-K9) controller 2500
Need some good configuration guide for AP 2600 and the wireless controller 2500.
any suggestions will be good
Here is a guide you should read also.  This talks about how an AP registers to a WLC:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
Here are the docs for you to configure the basic switch port config for AP's i.e 2600s and wlc.
Wlc port should be configured as trunk.
AP port has to be access.
CAP2600 series requires a wlc software of minimum 7.2.110.0 (Make sure you have this or above release)
To upgrade if you need to follow this.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805f381f.shtml
1. http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080665cdf.shtml (SW port configs)
2. http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
(ANother very importand thing, discovery mechanism, choose appropriately)
If you choose dhcp option 43, it uses TLV format. Type is always f1, length is 4*(no.of wlc for which you want to provide discovery for , in ur case one) Value = Hex conversion of the management ip address of wlc.
A video for the process,
http://www.youtube.com/watch?v=oOh_Iv1CHxQ.
Sandeep Choudhary
HI Sajjal,
Check this doc:
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/69719-wlc-lwap-config.html
Don't forget to rate helpful posts
