Configuration issue on 1231G AP
svaishya20
I configured one vlan and trying to authenticate it through radius server.My objective is when a internal users want to connect through this SSID they just put username and password and authenticate through Radius server. Another vlan is getting authenticated through mac address that i need to manually put in AP.
Can any one please tell me where i ma making mistake.
Saurabh
Hi Surabh,
bridge irb
You need to create  dot11 ssid
vlan x
vlan y
then  under interface radio 0/1 create subinterfaces
create encapsulation
bridge group command
similarly create on  gi 0  sub interfaces
Bridge route ip
interface bvi ip address
ip default gateway
connect AP to switch port  configured as trunk
check  your aaa commands
radius server  shared secret  command is required
https://supportforums.cisco.com/docs/DOC-14496
check this document  link
and that should help you
-Srini
Amjad Abdullah
Saurabh:
You need to provide more informaiton about your problem:
- are you using autonomous or unified AP? (for now I think it is autonomous).
-  what do you exactly mean by users to provide username/password pairs? where should they enter those info?
- is there any eap type you want ot use? (PEAP, EAP-FAST...etc)?
Beside the link provided by Srini about configuring multiple SSIDs, Here is a link which a bit show configuring 802.1x security on the SSID:
http://tiny.cc/qrj8bw
Hope it will be useful.
Amjad
Rating useful replies is more useful than saying "Thank you"
