Configuration of Cisco WLC 2504 with Local LAN static IP and DHCP
Ashish Kumar
I want to configure Cisco WLC 2504 with Local LAN static IP and WLC 2504 with DHCP so that APs can be connect with controller.
Currently i am using WLC 2504 with DHCP so can anyone suggest how to do that..
Sandeep Choudhary
HI Ashish,
Example:
Here WLC and AP are in same VLAN.
Here is teh attached config for WLC 2504.
Swicth port config where WLC connected:
interface GigabitEthernet 0/xx
description *** WLAN Controller ***
switchport trunk allowed vlan 80-81
switchport mode trunk
speed 100
duplex full
On core swicth DHCP pool is created to assign IP to AP:
ip dhcp excluded-address 10.xx.80.1 10.xx.80.100
ip dhcp excluded-address 10.xx.80.115 10.xx.80.254
ip dhcp pool WirelessLAN
   network 10.xx.80.0 255.255.255.0
   default-router 10.xx.80.254
   option 43 ip 10.xx.80.1
   lease 3
Swicth port config where AP connected:
interface FastEthernet0/xx
description *** AP ***
switchport access vlan 80
switchport mode access
Hope it helps.
Dont forget to rate helpful posts.
5 Replies 5
Sandeep Choudhary
HI Ashish,
Example:
speed 100
duplex full
   lease 3
Hope it helps.
Hi Sandeep,
Thanks for sharing the configuration.
Actually i don't want to use a switch in this scenario for DHCP, I just want to configure a port of WLC 2504 controller with static LAN IP and another one for DHCP configuration so that i can connect that WLC 2504 controller with my local LAN and APs with that controller.
HI Ashish,
Directly connected APs are not supported on the 2500 platform. Please see the 2500 deployment guide:
Check this Link:
http://www.cisco.com/en/US/products/ps11630/products_tech_note09186a0080b8450c.shtml
"The Power over Ethernet (PoE) ports on the Cisco 2500 Series Wireless Controller will not support directly attached APs."
Hi Sandeep
The info is correct, if we're using code below 7.3.101.0.
This issue is fixed via the below bug id.
CSCto01390 Unable to ping AP's directly connected to a 2500 controller
check the fix that is updated on 7.4, 7.5 RNE.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn75.html
Note
Directly connected APs are supported only in Local mode.
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps11630/data_sheet_c78-645111.html
For quick and easy deployment Access Points can be connected directly to 2504 Wireless LAN Controller via two PoE (Power over Ethernet) ports
Saravanan
#on 2500, ofcourse you can configure static ip on management and dynamic interface.
#Wired device can't get ip from WLC's dhcp pool, only AP and wireless can get ip.
