ā11-21-2011 07:16 AM - edited ā07-03-2021 09:06 PM
hello
i have bought cisco 892W router, i want to configure As Access point and connect two more 1142 Access points with this router.
i configure router and ap. but its not working. i am not getting ssid
please assist
current configuration of router AP as attachment.
thanks
vikas kumar
ā11-21-2011 07:20 AM
I didn't see an attachment. By the way, if your AP is a LAP1142, thy requires a WLC. You would need to convert that I autonomous.
Sent from my iPhone
ā11-21-2011 07:22 AM
Here is a link to the conversion
https://support.soundenterprises.net/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=28
Here is a link to configure the 1142
http://www.cisco.com/en/US/docs/wireless/access_point/1140/autonomous/getting_started/guide/ap1140aut_getstart.html
Sent from my iPhone
ā11-21-2011 08:21 AM
Dear scott
thanks for reply.
i forgot to attach file.
i am not able to configure 892W router AP.
first prob i have once i enter AP console from router console using service-module wlan-ap 0 session
i am not able to come out from AP console to Router console back.
i have configure AP with following configuration but SSID is not being broadcast.
i am sure i am doing some mistake.
please find config
router config:
conf t
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no shut
int vlan 1
ip nat inside
no shut
int wlan-ap0
ip unnumbered vlan1
no shut
end
AP config:
conf t
dot11 ssid TEST
vlan 1
authentication open
authentication key-management wpa version 2
wpa-psk ascii password
bridge irb
interface Dot11Radio0
encryption vlan 1 mode ciphers aes-ccm tkip
ssid TEST
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root access-point
no shut
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
no shut
interface GigabitEthernet0.1
bridge-group 1
interface BVI1
ip address 192.168.1.5 255.255.255.0
no shut
bridge 1 route ip
please assist
thanks
vikas
ā11-21-2011 08:29 AM
If you want to broadcast the SSID you need to enter guest-mode under the dot11 SSID.
Sent from my iPhone
ā11-21-2011 08:34 AM
Dear scott
thanks for reply
i will try this and let u know.
is my config is ok.
how can i come out from AP console to router console.
is there any command to come out ?
please assist.
thanks
vikas kumar
ā11-21-2011 08:36 AM
I think it's ctrl+z.
Sent from my iPhone
ā11-21-2011 08:40 AM
Try CTRLShift6+X
Sent from my iPhone
For multiple SSID's here is an example.
http://www.thestudycamp.com/forum/ccna/19003-how-broadcast-multiple-ssids-cisco-autonomous-ap.html
Sent from my iPhone
ā11-21-2011 11:22 AM
Dear scott
thanks so much.
i managed to configure router AP and its working fine,
now i need to configure 1142 AP.
i will configure and let you know
thanks so much for your support
regards
Vikas kumar
ā11-21-2011 11:24 AM
No problem. Just post if you run into issues.
Sent from my iPhone
ā11-21-2011 11:12 PM
Dear scott.
thanks for support,
i need one fevor, from where i can download c1142-k9w7-tar
thanks with regards
vikas kumar
ā11-22-2011 06:28 AM
Dear Scott,
i have tried to do with TFTP.
Start time Client Address File Mode Size Transferred Blocksize Timeout Status Description
11/22/2011 5:06:13 PM 10.0.0.1:1024 c1140-k9w7-tar.default octet 4791401 0 512 5 Client error. Failed to download file from server. Client returned: Timeout occured.
i got this error.
i have enable password login to console and access AP from Telnet but cant access via web.
please help.
regards
Vikas kumar
ā11-22-2011 08:05 AM
Make sure you have your firewall turned off on your laptop/pc. I use 3cdeamon tftp as my tftp client.
ā11-22-2011 12:13 PM
