06-29-2015 05:07 AM - edited 07-05-2021 03:28 AM
I have a wireless access point, how can i connect it to a layer 2 switch thorough it's layer 3 interface.
what configurations do I need on wireless access point and layer 2 switch?
If I want to connect this access point to a layer 3 port on a layer 3 switch, what configuration do I need on both of them?
Thanks in advance,
06-29-2015 05:31 AM
Here is the sample config for lightweight AP:
interface FastEthernet0/10
switchport access vlan 50
switchport mode access
no shutdown
Autonomous AP:
int Fa 0/10
switchport mode trunk
switchport trunk native vlan 50
switchport trunk allowed vlan 1,50
Don't forget to rate helpful posts
06-29-2015 05:54 AM
Thanks for your answer,
But I want to connect my AP through it's layer 3 interface to next hop device,
now if next hop device was layer 2 device or layer 3 device, the configuration of connected layer 3 AP wouldn't change?
There are several SSID on AP that I want to config them on different VLANs and through connected link between AP and next hop device pass them. now how can I configure this layer 3 port on AP according to next hop (layer 2 or layer 3 device)?
06-29-2015 06:07 AM
I am not sure i understood right or not .....
1. now if next hop device was layer 2 device or layer 3 device, the configuration of connected layer 3 AP wouldn't change?
- Yes it wouldn't change
2. Config of layer3 or layer2 is almost same:
For layer 3:
int Fa 0/10
swithcport
for Layer2:
int Fa 0/10
06-29-2015 06:31 AM
Thanks again,
I know what you mean, but the port on AP that is connected to next hop device is not a layer 2 port, it's a layer 3 port. In this situation how can I do?
