four way handshake
Hi ,
Can you explain four way hand shake step by step  in wap2 enterprise ? I read some document but I dont understand exactly
why is derive PMK , PTK ,  PGK .
isn't   An hacker  capture this value . Help please
6 Replies 6
Stephen Rodriguez
take a look at this post by George, here
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
thank you very mush for help . I am so busy at work noawadays . I studied your document later
Can I ask you something else in the meantime ?
What can I do for open ssl vulnerability . I have 4404 WLC , ACS 4.2 and NCS at work
this products are affected this vulnerablity . Can you help me ?  thanks
this products are affected this vulnerablity . Can you help me ?  thanks - See more at: https://supportforums.cisco.com/discussion/12538966/four-way-handshake#comment-10593131
What can I do for open ssl vulnerability . I have 4404 WLC , ACS 4.2 and NCS at work - See more at: https://supportforums.cisco.com/discussion/12538966/four-way-handshake#comment-10593131
thank you very mush for help . I am so busy at work noawadays . I studied your document .take care - See more at: https://supportforums.cisco.com/discussion/12538966/four-way-handshake#comment-10593131
Refer the link : Multiple Vulnerabilities in OpenSSL (June 2015) Affecting Cisco Products
http://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20150612-openssl
Rasika Nayanajith
Here is another reference with some packet captures to explain it
http://mrncciew.com/2014/08/19/cwsp-4-way-handshake/
Rasika
