Configure AIR-AP1850 as Standalone
twanaothman
I have no experience with Cisco wireless products and  I have a single Cisco AIR-AP1850 and want to configured as standalone but this message didn't allows me to do anything (CAPWAP State: Discovery).
Someone suggested that I need to upgrade the firmware then I purchased this (AIR-AP1850-K9-ME-8-8-111-0) from Cisco but still didn't allow me to upgrade the image while there is ping between AP and TFTP server and logs shows that transferring image were successful
TFTP server logs  is attached and your commend is highly appropriated
show version output
cisco AIR-AP1852I-E-K9 ARMv7 Processor rev 0 (v7l) with 997268/784320K bytes of memory
New Image name :
2 Accepted Solutions
Sandeep Choudhary
If you have a CAPWAP AP then first you nee dto ugarde to ME.
here is the method:
https://www.semfionetworks.com/blog/convert-a-cisco-capwap-ap-to-a-mobility-express-ap
2. After conversion, chekc this post to deploy:
https://www.packet6.com/deploying-cisco-mobility-express/
Dont forget to rate helpful posts
you need to have a .tar image if you want to convert from CAPWAP to ME.
.ZIP file are used to upgrade the ME software on AP.
Sandeep Choudhary
here is the method:
Hi Sandeep Choudhary ,
my new image is .zip should I convert it to tar ? if so , could you please guide me how to do it ?
