configure to broadcast 2 ssid on the same radio interface
Ed Lo
I'm trying to put 2 ssid on the same radio interface but each time it keeps telling me that no vlan are configured in MBSSID mode. What do I need to do? I've tried google in the hopes of finding something but, I had no luck with it.
thank you
7 Replies 7
Hello
Can you post you existing config please?
res
Paul
Kind Regards
Paul
Current configuration : 3016 bytes
version 12.4
no service pad
hostname ap
enable secret 5 $1$nD9N$8fK4tS4Yb8k7rTYyosEU2/
no aaa new-model
dot11 syslog
dot11 ssid batman
guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
ssid batman
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path
line con 0
privilege level 15
login local
no activation-character
line vty 0 4
login local
cns dhcp
end
Rasika Nayanajith
Pls check you config with below sample config & see if anything is missing. In my example I have assigned those two SSIDs into two different vlans
hostname AP-01
dot11 ssid <SSID1>
vlan 10
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii <SSID1_PASSWORD>
dot11 ssid <SSID2>
vlan 20
authentication open
mbssid guest-mode
wpa-psk ascii <SSID2_PASSWORD>
encryption vlan 10 mode ciphers aes-ccm
encryption vlan 20 mode ciphers aes-ccm
mbssid
ssid SSID1
ssid SSID2
no shut
channel width 40-above
mbssid
ssid SSID1
ssid SSID2
no shut
interface Dot11Radio0.10
encapsulation dot1Q 10
bridge-group 10
interface Dot11Radio0.20
encapsulation dot1Q 20
bridge-group 20
encapsulation dot1Q 1 native
bridge-group 1
interface Dot11Radio1.10
bridge-group 10
interface Dot11Radio1.20
bridge-group 20
bridge-group 1
interface GigabitEthernet0.10
bridge-group 10
interface GigabitEthernet0.20
bridge-group 20
bridge-group 1
interface BVI1
ip address 192.168.1.2 255.255.255.0
ip default-gateway 192.168.1.1
end
Rasika
*** Pls rate all useful responses ***
Thank you this helps.
Do the vlans have to be configured before doing this? I've struggled a bit at finding how to configure a vlan.
How you connect this AP to rest of your network ?
Is it connect to a Cisco switch or is it connect to unmanaged switch ?
Do you want those two SSID in two different vlans ? or same vlan ?
If you can provide  answers to above and give us your existing config (show run  output form AP CLI) removing passwords/sensitive info, we can have a look and suggest how you can achieve what you want.
Rasika
It's not connected to a switch and different vlan would be preferable. As i said in the post i can only get it to broadcast the current ssid any attempts I've had to add another only result in errors. It will result in saying "no vlan are configured in MBSSID mode" and the radio does not start up.
The following is the current config:
version 12.4
no service pad
hostname ap
no aaa new-model
dot11 syslog
dot11 ssid batman
guest-mode
bridge irb
no ip address
no ip route-cache
shutdown
ssid batman
antenna gain 0
station-role root
bridge-group 1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
bridge-group 1
interface BVI1
no ip route-cache
ip http server
ip http help-path
line con 0
privilege level 15
login local
line vty 0 4
login local
cns dhcp
end
if you erase your existing config and apply sample configuration I have given in the first response that should work (SSID name & password modify accordingly)
In my example vlan 10 and vlan 20 assign for those two SSIDs. You need to define those vlans gateway on your switch where this AP connects. In that scenario, AP connect switchport config should be like below.
interface GigabitEthernetx/x
switchport trunk allowed vlan 1,10,20
switchport mode trunk
AP management on vlan 1 (in my example 192.168.1.0/24 is assigned for that)
Rasika
