How to create a wireless network for a large house?
carterturner
Can somebody explain the best way (which will give best performance) to set up a wifi network across a large house?
If money were almost no object, how would one set it up so that you could get a strong wifi signal in every room from the basement to the attic? (preferably while staying on the same wifi network device video eg. so that it doesn't require any skill on the part of the user to change networks etc.) The goal being to be able to watch streaming video in any room on an iPad/iPhone etc.
I am eager to learn how this is done!
Thx
Leo Laohoo
Turn OFF 802.11b radio.
If money's no object, then put an AP in every room.  And turn OFF the bloody 802.11b radio!
Rasika Nayanajith
If it is a large house, then you may need to install more than 1 AP. (depend on the signal propagation through your building materials). If you are construction stage of your house, I would install data points (cat 6 cabling) to each bed rooms/ common area that you require WiFi signals strongly from the your home DSL/Internet entry point.
Assuming your Home DSL/Internet modem got many wired ports, then you can connect those AP to your internet modem for connectivity.
If you are using Cisco autonomous AP (eg 1142, 3502 that you can find cheaply on 2nd hand market), you can have basic config like this across all your APs
conf t
hostname <AP_HOSTNAME>
dot11 ssid <SSID_NAME>
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii <SSID_PASSWORD>
interface Dot11Radio0
encryption mode ciphers aes-ccm
ssid <SSID_NAME>
no shutdown
interface Dot11Radio1
channel width 40-above
ssid <SSID_NAME>
no shutdown
interface BVI1
ip address dhcp
end
write memory
As Leo said, you can turn off 2.4GHz (radio 0), if you want to have higher performance/throughput for your video services.
Rasika
*** Pls rate all useful responses ***
