Configure Wireless Lan on 876W Router
asarida01
HI,
i have a 876W Router which is connected to the internet throw a wireless connection to another modem/router, through Access Points. On the side of the modem/router there is a LAN With IP 192.168.0.1. I have create a second lan as VLan with IP 192.168.100.1 on my router. On modem/router i have declare the seconf ip as Virtaul Interface and with that way i have access to the internet.
When i am connecting to the lan through Etrhernet switch port 1 (on Ethernet switch port 0 there is the wireless Access Points that links to the modem/router) and i ask for 192.168.100.1 the router sends the IP to the modem/router and i get a connection on 192.168.0.1, and so everythink is ok. The VLAN on my router is configured to 'VLAN For Routing' (that's the option on SDM).
Now i am setting ethernet switch port to TRUNK, i am creating a wireless connection, i connect from my PC's wireless card to the router (192.168.100.1),so far so good, i have declare in my pc the apropriate IPs, and now i do not know how to configure the router to connect to 192.168.0.1 ip instead of 192.168.100.1, something that i do when i use ethernet switch port 1...
could somebody help????
a-vazquez
Level 6
Level 6
I feel this document will be very useful to you. This explains how to configure a Wireless LAN connection on a 870 router. Check it out.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a008045d289.html
