Configuring Access Points for Two Separate Networks
Spidey's Curse
Visitor
I will preface by saying that I am still a novice with Cisco configurations. I am getting better, but man....some of this stuff is WAY over my head.
I will try to be as detailed as possible here.
So, what I am trying to do is create two networks. The biggest huddle I am going through here is just trying to get my wireless controller to talk to my domain controller.
My set up is:
9800 Core Switch -192.168.0.10
C9120AXI-B  with wireless controller enabled.
I also have 5 C9105AXI-B access points.
I have my access points on a 10.0.10.1 network
As stated, I just need to figure out how to get the wireless networks that I created to get to the domain controller.
I tried using DHCP 43, but it just doesnt work and I have a feeling that I just have something way misconfigured.
Do I need to create a VLAN for each wireless network (guest and office wifi)on my core switch?
For instance, I would like to have devices that connect to the office network something like
Office - 192.168.25.0
Guest - 192.168.20.0
Do I need to configure the VLAN on the core switch first?
When I create the VLAN on the core switch, am I tagging ALL ports for the wireless VLANS, or do I just tag the ports that I have the wireless controller and the access points? Assuming I would make those trunk ports.
After I configure the VLAN on the core switch, how do I get the wireless controller to direct traffic to the domain controller?
I think as soon as I am able to get the access points to see DHCP, I can figure it out from there, Im just really struggling how to get everything connected here.
I apologize in advance if this is a bit of a chaotic question, but any response, advice or guidance is very greatly appreciated!
Mark Elsen
  >...As stated, I just need to figure out how to get the wireless networks that I created to get to the domain controller.
  >I tried using DHCP 43, but it just doesn't work and I have a feeling that I just have something way misconfigured.
    These statements are blurred , fuzzy and incorrect ; for instance DHCP option 43 is only used for APs to have them discover a controller. You don't have wireless networks 'get to a domain controller' , well they might depending on the intranet layout : it looks more like you need basic training and expand fundamental knowledge before returning to the forum (tx),
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Rasika Nayanajith
"9800 Core Switch -192.168.0.10"
What is it exactly, 9800 WLC or a switch? If it is WLC you have to set it up first where those APs (9120 and 9105) come and register. If that WLC has configured with initial configuration, please check from your APs you can reach out (simply PING from WLC to APs)
For APs to know about WLC MGT IP, you can configure DHCP option 43 on AP management subnets. If you have a AP SSH or console access, you can simply try "capwap ap primary-base {9800_WLC_Name} {WLC_MGT_IP}" CLI command to verify your AP able to register with 9800
Regarding vlans, you need to define them on 9800 connected switch and create SVI (vlan interface) on that switch. On 9800, you just need L2 vlans and no SVI required for client vlans.
Rasika
*** Pls rate all useful responses ***
Rich R
Like Marce says some clarification needed and I highly recommend reading docs and watching videos to understand what you're working with before you start configuring.  Also use sample/example configs and adapt as needed for your own use.
As @Rasika Nayanajith 9800 is not a switch it's a wireless LAN controller.  Having a WLC and C9120AXI-B  with wireless controller enabled (EWC) is NOT SUPPORTED - it will cause problems.  Maybe you meant some kind of Catalyst 9x00 switch?
Yes the APs must be connected to trunk ports on the switch.
The APs must all be on the same AP management VLAN (which will be the native VLAN on the AP trunk ports) and they will discover the EWC automatically by subnet broadcast (no option 43 needed).  You DHCP can simply be a pool for that VLAN on the switch.  Does no harm to configure option 43 but not essential.
Yes you should have a separate VLAN for each WLAN/SSID.  The APs use flexconnect local switching to bridge the client traffic direct to those VLANs from the APs.  Yes the VLANs should be configured on the switch and allowed on the AP ports.
What do you mean by "trying to get my wireless controller to talk to my domain controller."? Are you wanting to use the DC for wireless user authentication or you just want the users to be able to connect to the DC?
https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/q-and-a-c67-743152.html
https://www.cisco.com/c/en/us/support/docs/wireless/embedded-wireless-controller-on-catalyst-access-points/215303-embedded-wireless-controller-conversion.html
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213911-understand-catalyst-9800-wireless-contro.htmlhttps://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/at-...
https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-9/config-guide/ewc_cg_17_9.html
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-743627.html
When reading the guides remember EWC only supports flexconnect local switching.  The EWC does not support any central switching, VLANs, SVIs or any other feature which depends on VLAN or SVI.  The EWC WLC has only 1 single IP interface which doubles as the management access (SSH and GUI) and the AP management (CAPWAP) interface.  The AP part uses the VLAN purely to switch the wireless client traffic to the VLANs.  The EWC does not store AP images so all AP images must be downloaded from a TFTP server (TFTP server IP is configured on the EWC which tells the AP where to fetch the image).  You could use your switch as the TFTP server.
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
