Configuring AIR-WLC4402-50-K9 through CLI
decrypted08
I have many  AIR-WLC4402-50-K9  devices to configure and the cli is frusterating- does anyone have a link to a step by step document that walks through assigning an IP, SSID, and enabling the radios using the cli?  I cant seem to find one that works completly.  I just need to assign it an ip so I can use the web gui!
Thnaks
here is the details..
en
conf t
dot11 ssid <>
guest-mode
authentication open
end
The above command will do it for you!!
lemme know if this answered your question!!
Surendra
Please dont forget to rate the posts which answered your question or was helpfull
Surendra BG
22 Replies 22
Surendra BG
This is the command to assign the IP address...
CONFIG INTERFACE ADDRESS MANAGEMENT
Ex
CONFIG INTERFACE ADDRESS MANAGEMENT 10.10.10.224 255.255.255.0 10.10.10.1
CONFIG INTERFACE ADDRESS AP-MANAGER 10.10.10.224 255.255.255.0 10.10.10.1
Then issue the commandto enable WEB access and TELNET access.
CONFIG NETWORK WEBMODE ENABLE
CONFIG NETWORK TELNET ENABLE
Here is the link which gives info on the complete command guide for WLC... (This needs CCO login to view)
http://www.cisco.com/en/US/partner/docs/wireless/controller/6.0/command/reference/cli60.html#wp1321947
Lemme know if this answered your question..
Surendra
Please rate the posts which answered your quiestion or was helpfull
Surendra BG
it doesnt work:
I have to start in an elevated mode right?
enable - password - right?  then what? configure radio0 ...... ?
The WLC CLI is completely different.. the command which i provided will help you out.. here is the command.. There is no En or dot11 0 commands on the WLC CLI..
(Cisco Controller) >
(Cisco Controller) > CONFIG INTERFACE ADDRESS MANAGEMENT 10.10.10.224 255.255.255.0 10.10.10.1
(Cisco Controller) > CONFIG INTERFACE ADDRESS AP-MANAGER 10.10.10.223 255.255.255.0 10.10.10.1
(Cisco Controller) > CONFIG NETWORK WEBMODE ENABLE
(Cisco Controller) > CONFIG NETWORK TELNET ENABLE
Surendra
Surendra BG
Oh!  I am so sorry, I ment the access point not the wlc- err my appologies,  its the
1130ag access point im connected to!
AP is in Autonomous mode or in LWAPP mode?? i mean you do not want to use WLC right??
If its in Autononmous mode.. then the below command will help you..
AP>en
password:
ap#conf t
ap(conf t)#int bvi 1
ap(conf-if)#ip address
ap(conft-if)#no shut
ap(conft-if)#exit
ap(conf t)#ip default-gateway
ap(conf t)#end
Example..
AP>en
password:
ap#conf t
ap(conf-if)#ip address 10.0.0.2 255.255.255.0
ap(conft-if)#exit
ap(conf t)#ip default-gateway 10.0.0.1
This will help you!!
if you are not able to go to the CONFIG mode after entering the command CONFIG T, then the AP will be in LWAPP mode and you need to convert the same to Autonomous.. here is the link..
https://supportforums.cisco.com/thread/2055997
Surendra
Surendra
Surendra BG
Ok so this configured the ip of the bridge interface, i still need to assign a SSID and enable the radios right?
ok.. i tot this post is for getting the GUI access.. is that right?? now u can iopen up the browser and hit the BVI ip and then you can get the access to the GUI..
here is the link to configure WPA auth and SSID..
The below link will help you out in getting the basic wireless config on the AP..
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008055c39a.shtml
here is the link for WPA-2 PSK as well
https://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml#pers
Surendra
Please dont forget to rate the posts which answered your quiestion or was helpfull
Surendra BG
I still cannot get access to the AP- i configured an SSID of TEST assigned radio
0 and 1 ip address but there is nothing broadcasting for me to connect to!  How can i access the gui
wirelessly ( i dont have a crossover cable)
if you have the access to the AP CLI.. then issue the below command..
en
conf t
dot11 ssid
GUEST-MODE             >>>>>>. This command will bradcast the SSID
end
wr                       >>> To save the config..
Surendra
Surendra BG
Everythings working??
lemme know if this answered your question..
Surendra
Please dont forget to rate the post if this answered your question or was helpfull
Surendra BG
Well no, Its not broadcasting anything-  thought the interface ip is configured
Thats because you have not configured anything.. please have a look into my previous reply and lemme know how this works
Surendra
Surendra BG
Surendra BG
oops sorry.. the AP-MANAGER should be assigned to a different ip.. here is the example again..
then
Surendra
Surendra BG
after show conf- it looks like radio is up and with an ssid but i dont see any available in wireless network to connec
t to to get to the gui...
interface Dot11Radio0
ip address 10.10.10.100 255.255.255.0
no ip route-cache
ssid test
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled...
interface BVI1
ip address 10.10.10.5 255.255.255.0
no ip route-cache
