Configuring AppleTV for Wireless deployment without WLC (881->3560->AP)
ElwinMkanyika
Hi Guys,
I have read the Wirelss deployment guide provided but i do not seem to get AppleTV to work on the wireless network. When connected to the wired network - all is ok.
Design -
Cisco 881 -> 3560 -> AP
Here is what i have so far:
Router Config:
ip multicast-routing
no ip igmp snooping
interface FastEthernet0
switchport mode trunk
interface FastEthernet1
switchport access vlan 5
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
mac-address *****
ip address *****
interface Vlan1
ip address 192.168.0.5 255.255.255.0
ip pim sparse-dense-mode
interface Vlan5
description --Data--
ip address 192.168.5.254 255.255.255.0
interface Vlan6
description --Media--
ip address 192.168.1.254 255.255.255.0
Switch config
A-01#sh run
ip igmp snooping querier
vlan internal allocation policy ascending
vlan 5
name Data
vlan 6
name Media
interface GigabitEthernet0/1
description <<To_G-01>>
switchport trunk allowed vlan 1,5,6
switchport nonegotiate
interface Vlan1
ip address 192.168.0.223 255.255.255.0
ip pim rp-address 192.168.5.254
AP Configuration
no ip igmp snooping
no dot11 igmp snooping-helper
Please help me properly configure the network to support AppleTV. We currently use vlan 5 and 1 only. vlan 1 is management and vlan 5 - basically data and media.
Faith
9 Replies 9
Scott Fella
What code are you running on the AP? I have had some peers upgrade to v15 and broke their bonjour. Having the firmware at v12 works.
-Scott
Scott,
Thank you for your time.
I hope you do not mind my rather uneducated answer:
How do i find out the code that i am running on the AP?
Show version and then post that. That will show you the version the AP booted.
You can also issue a show boot from the CLI and also a show dir to show the flies
-Scott
Am used to it being called IOS
Here we go.
flash:/c1140-k9w7-mx.152-2.JB/c1140-k9w7-mx.152-2.JB
You believe I should downgrade to v12?
Could we first confirm that the configuration is ok so that i can resort to downgrade as a last resort because the AP is in exploitation at the client's site.
Could you please confirm that my multicast configurations are correct ?
Thank you for your time Scott!
Faith.
The configurations look fine from what I also have read on the forums.  I just know the v15 has broke the bonjour stuff.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Thank you Scott!
Will try downgrade then get back to you! Thank you for your replies.
Reagrds,
Faith
Let me know how it goes.
Scott
-Scott
Hello Scott!
So I finally got to  downgrade to v12 but appleTV is still not working
Any more suggestions?
Faith
try to enable ip igmp snooping-helper command on the AP
how it goes ??
