Configuring Cisco 2100 WLAN controller to authenticate with Windows 2003 IAS using RAIDUS
TECH-JEFF
Hi, I'm new to this device and need to setup a wireless environment for our office using Cisco 2100 WLAN controller. Trying to browse over its GUI to heck where shall I input the settings for it to authenticate with our Windows Server using IAS that supports RADIUS? Appreciate any help on this.
Thanks in advance
Jeff
Jefferson Co
6 Replies 6
Hi, this is indeed helpful for me, will try this and giv you feedback if I'm successful, really appreciate this.
Jeff
Jefferson Co
Hi Sandeep,
I'm already on the part where you will need to add a vlan for the WLAN my next issue is since this is a task that was initially configured but was not completed, how will I know the existing vlan that was previously created for WLAN, I've confirmed with my manager that a vlan was created for this wlan but was not completed by the vendor, How will i know this vlan?
Jeff
Jefferson Co
Hi Jeff ,
Do have GUI access to WLC??
If u have then go to Controller>interface and check which interface is assigned to WLAN.
Or check from here :
WLAN > WLAN id open this and check which WLAN have which interface .
Don't forget to rate helpful posts
Yes I do have GUI access, actually I was already successful in the part of creating a vlan for the WLAN, when I tried to perform the vlan creation, it said that I was overlapping with another vlan, when I show ip route saw the vlan that was created before and confirmed with my manager if that was the one created by the vendor, and indeed this was the vlan.
My next issue is, after installing IAS, was trying to request a certificate for the member server (IAS) but got this error message:
Jeff
Jefferson Co
