Configuring Guest Access using 2 LWAPs and 2504 WLC
Please advise,
I have 2 APs, Cisco Aironet 1040, and 2504 WLC.
Is it possible to configure guest access (Guest SSID/VLAN and Corporative SSID/VLAN) without dedicated guest WLC in DMZ?
2 Accepted Solutions
Scott Fella
Yes you can. You can have up to 16 SSIDs per AP, but not suggested to have all 16. You can either use one port on the 2504 for both SSID/vlan or specify which port is for corporate and which one is for guest.
Scott Fella
Sent from my iPhone
-Scott
Scott Fella
Here is a good guide on the 2500
http://www.cisco.com/en/US/products/ps11630/products_tech_note09186a0080b8450c.shtml#scenarios
Scott Fella
Sent from my iPhone
-Scott
Scott Fella
Scott Fella
Sent from my iPhone
-Scott
Scott Fella
Scott Fella
Sent from my iPhone
-Scott
Thank you, Scott!
No problem
Scott Fella
Sent from my iPhone
-Scott
