Configuring LocalNet Users
Rob Johnson
In the link below I see where there is a 24 character limit for localnet users.  However, the only time you get an error when trying to add a user(s) w/ more than 24 characters is from the CLI(the GUI doesn't give an error)
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_0101111.html
Questions::
1) What authentication type(s) can be used on the WLAN to use these localnet users?  LEAP, EAP Fast....  what else?
2) If from the GUI a localnet username with more than 24 characters is used, can it login?
3 Accepted Solutions
Scott Fella
Rob,
You can use the local net user for WebAuth also. It also fails if you create a password larger than 24. I tried it with a password of 30 characters.
-Scott
I just tried it again... 24 and under works, anything over 24, I get a login error.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Running the TAC release v7.6.100.4
-Scott
5 Replies 5
Scott Fella
Rob,
-Scott
Scott,
Please try if you will to create a user with more than 24 characters via the GUI then try to login using that ID.
For me, if I was doing my Webauth correct today, it worked!!!  which is totally messed up::::
Scott
-Scott
Thanks Scott,
What version of code was your WLC running?
-Scott
