Configuring SSIDs in Lan Controller
jose2r
Visitor
With the model AIR-LAP1131AG-E-K9 I only can configure 8 SSID and I need to configre more than 8.
is it possible?
ankbhasi
Hi Jose,
As of now with 1130 APs the restriction is of 8 SSIDs but if you want you can create more than 8 interfaces with different vlans and using AAA override feature with this 8 available SSIDs you can assign more vlans to wireless machines based on user identity.
Ankur
*Pls rate all helpfull post
