configuring wireless on cisco 877w router
vincent-n
Level 3
Level 3
Hi all
I have a Cisco 877W wireless/ADSL router and having great difficulty with configuring wireless on this router. Here is a quick summary.
1. The ADSL is configured to obtain public IP from the ISP
2. Default interface vlan 1 is configured with an IP address
3. I went into vlan database, tried to configure multi vlans and the router prompted me that it can only have max 2 vlans. Hence what's the use of up to 16 different SSID using wireless?
4. I've setup DHCP scope on the router to give out IP address to clients (both wireless and wired)
5. I'm able to configure WPA-PSK on the router and was able to connect wirelessly to the router but I won't be able to obtain an IP address from the router
6. There are two scenarios that I'd like to do:
A. Setup wireless to connect to the same subnet as what's on vlan1
B. Setup wireless to connect to a different subnet to vlan1
For the life of me, I could not find docs on Cisco web site that shows me how to exactly this. I found some documents that use interface F0 as a trunk port and treat the interface Dot11Radio0 with sub-interfaces. I don't connect this router to a switch (standalone router) so how can I do this? Please point me to some docs.
Thanks in advance for your help.
vincent-n
Level 3
Level 3
Oh, and here is a sample of my config
ip dhcp excluded-address 10.116.3.1 10.116.3.8
ip dhcp pool ABC
import all
network 10.116.3.0 255.255.255.224
dns-server 10.95.3.8 10.95.3.10
default-router 10.116.3.1
no ip address
encryption mode ciphers tkip
ssid MM-Wireless
authentication open
authentication key-management wpa
wpa-psk ascii 0 abc123456
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
ip address 10.116.3.1 255.255.255.224
Also, 'd liek to be able to broadcast out this SSID if possible. On my workstation, it keeps coming up as "SSID Not Broadcast". Thanks.
Stephen Rodriguez
Best bet here, is to configure a BVI interface on your router, and move the IP address from the vlan to the BVI, place the vlan in to bridge-group 1, and save and reload. having sub interfaces on your dot 0 radio works for having different SSID's, but you still need the BVI (bridged virtual interface) to Communicate on.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
My configuration works for wireless no authentication, but failed for WPA-PSK:
ip dhcp excluded-address 172.16.250.1
ip dhcp pool TEST
import all
network 172.16.250.0 255.255.255.0
default-router 172.16.250.1
bridge irb
interface FastEthernet4
description $ES_WAN$
ip address dhcp client-id FastEthernet4
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no ip address
ssid 111
vlan 1
authentication open
wpa-psk ascii 0 Cisco1234
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 172.16.250.1 255.255.255.0
ip nat inside
After I configured the same wpa-psk key on the XP computer using windows zero configuration and tried to connect to the wireless work, I got the following errors on the router:
*Mar 1 03:00:51.623: *** Not encrypted dot1x packet from 000c.f123.25cf has been discarded
*Mar 1 03:00:52.623: %DOT11-7-AUTH_FAILED: Station 000c.f123.25cf Authentication failed
What could be wrong? Thanks!
