Console cable for Cisco AP model 350 - needed
gtelles
Community Member
Anyone know how to use the existing Cisco console cable for the model 1200 (9 pin female to RJ45) on the old model 350 with a female 9 pin serial port. I have tried 9 pin adapters with the Cisco console cable.
To compound problems I have laptop with only a USB port no serial interface. This is not a problem for the 1200 console cables and a serial to USB adapter, but it makes this adaptation even more difficult.
Greg
wong34539
Level 11
Level 11
You can buy a usb to serial converter for your laptop.here is the pin configuration.
RJ45 DB9
1 ... CTS ... 8
2 ... DSR ... 6
3 ... RXD ... 2
4 ... GND ... 5
5 ... GND ... N/C
6 ... TXD ... 3
7 ... DTR ... 4
8 ... RTS ... 7
DB9-RJ45 ADAPTOR PIN CONFIGURATION
RJ45 DB9 RJ45 DB9
PIN # PIN # PIN # PIN #
1 8 5 None
2 6 6 3
3 2 7 4
4 5 8 7
http://www.cisco.com/en/US/products/hw/routers/ps332/products_tech_note09186a0080094ce6.shtml
The Cisco 1200 console cable is unusable on the model 350. The only cable usable is a straight through 9 pin serial cable with male on one end and female on the other. I had the USB to serial cable already and was hoping to use the console cable from the 1200. This is not possible even with gender changers.
