Console is stuck there when plugging into AP
interfacedy
Hi Console is stuck there, please see the below error message. and cannot type anything only when the console is plugged into the AP c9130. Anyone has experience about this? Thank you
% Authentication failed
No valid user found, please configure a valid user from Controller
2 Accepted Solutions
Scott Fella
Keep the console connected and reboot the ap. If you see an output on the console, then there is no issue. Try to factory reset the ap to make sure there is no configuration that was in place cause the issue. Hold the mode button for 20 seconds while powering up the ap. The led will flash res around the 20 second mark.
-Scott
Sadav Ansari
This is hitting the bug pls check the below link for your reference.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvv59015
If this answered your question, please click "ACCEPT AS SOLUTION"
If you find this response useful, please mark it as "HELPFUL"
6 Replies 6
Scott Fella
-Scott
Can confirm this worked for me. Using C9120-AXI-B.
interfacedy
The way you mentioned can work, but all these kinds of ap have this issue once joining. we might have another way to resolve it from wlc, but so far we do not know it.
Sadav Ansari
The bug does not mention a workaround.
plongino
Hello @interfacedy
As it states "configure a valid user from Controller", Just configure a user on your AP profile
Example
EWC(config)#ap profile <profile-name>
EWC(config-ap-profile)#mgmtuser username admin password 0 Cisco123 secret 0 Cisco123
plongino
