Console problem is WLC 8540
rohitbhanu009
I m unable to take console of the wlc 8540. When i connect the CIMC cable and connect the console i m getting the below error message.
õÛëýÿõõëõíýÿÿýõýÿõýÿÿÿõýÿý
in console i have put the below parameter
Baud rate 9600
data bit 8
stop bit 1
parity non
flow control None
Rasika Nayanajith
Did you connect your console cable to the 2nd port from the left shown below
Ensure above console settings works well with any other devices first as well.
Rasika
*** Pls rate all useful responses ***
We are using KVM
Front Panel KVM Break-out Connector
A single female connector provides access to video, two USB ports for keyboard and mouse, and an RS-232C console serial port.
And getting the
Baud rate 9600
data bit 8
stop bit 1
parity non
flow control None
can some please help
