controller 2112
jeanjborrull
Community Member
hi
my controller is a 2112 with firmware version 7.0.164
I have a wcs server installed on a Windows 2003 version is 7.0.220
my problem
I have a configuration for the week of 5:00 p.m. to 11:00 p.m.
. This configuration work-
On configuration the WLAN
      -I turn the signal to 5.00 PM
     - I turn off the signal at 11.00 PM
I would like a setup for the weekend who works 12 hours Saturday to Sunday 23 hours
how I can do that
thank you
Amjad Abdullah
Jean:
Where is your configuration please? What template that you use?
There is no WLC firmware 7.0.164. There is WCS 7.0.164 and I don't think it is compatible wiht WLC code 7.0.220.0.
Verify both WLC and WCS versions and let us know.
Thanks.
Amjad
Rating useful replies is more useful than saying "Thank you"
Scott Fella
Just to add... WCS/NCS/MSE should either be on equivalent firmware versions or higher (newer) than the WLC firmware version.
If you search the forum, what others have done is to create a WLAN template, one that disables and another that enables the WLAN. Then you can setup the template to run on a schedule. So you would have different templates for the weekdays and for the weekend.
-Scott
