Controller command question
taimoor khan
Level 3
Level 3
Hello Guys,
just a simple question, how do I use """""""""" | INCLUDE """"" in WLCs. I am unable to find pipe option in WLC CLI could anyone help. I am trying to search
sh runnin | include capwap --------- but its not working
runing 7.3.103.14
2 Accepted Solutions
Scott Fella
There is no pipe in the AirOS which the WLC runs. In the 3850 and 5760's you can since they are IOS.
-Scott
Scott Fella
Capwap is default for WLC's with the newer code, that's why I ask what exactly are you looking for.
-Scott
9 Replies 9
Scott Fella
-Scott
thats gona increase my work !
Thanks for reply scott, how do I check capwap for all controller at once ?
What exactly are you looking for?
-Scott
we have couple of AP down and want to see is there any problem with CAPWAP.
Well an ap not joining usually is a network related issue. You can alway go to the GUI and under Monitor, look at the statistic for ap join.
-Scott
Scott Fella
-Scott
Scott Fella
You can only see stats or information when the ap is joined to the WLC. Other than that, information from the ap console shows good information. Also looking at the switch port for errors or the switch logs can help.
-Scott
thanks for quick reply, seems like a network issue.
Abhishek Abhishek
As per your query i can suggest you the following solution-
I agree with Scott as there is no pipe in the Air OS which the WLC runs. In the 3850 and 5760's you can since they are IOS.
Hope this will help you.
