I'm deploying a LWAPP solution over a MobileAccess distributed antenna system (DAS) using AP1242s. the A & B/G antennas are connected to the primary (right side) antenna outputs. The 4404 WLC (wireless->access points->radios->802.11a/n or 802.11b/g/n) has the AP configured with diversity enabled. The AP are installed on shelves in stacks of 4, with very little spacing between the the APs. My question is do I need to set the "diversity" setting to right? If so, what is the easiest way to do that through WCS?
Todd
