Controller timeout
TRACY HARTMANN
Level 4
Level 4
We have a 4400 controller and users are complaining that their access timeout after 5 minutes.  The only thing on the controller that I see is a 300 user inactivity timeout.  Is there another way to setup a timeout?
Stephen Rodriguez
In the WLAN, do you have the Session Timer configured?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Where would I check that configuration?
Scott Fella
Just to add to Steve's post....
If using WebAuth, set your idle timer to 2-4 hours.  Make sure that the session timer is higher than the idle timer.  The session timer is using webauth is nice to set at 8-24 hours.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
