Conversion from vxworks to ios problem
ggozzi
I'm trying to convert an ap 350 vxworks in ios and I'm unable to found the dowload site the image called
AP350-Cisco-IOS_Upgrade-Image-v2.img
Can anyone help me?
Thanks and regards
cspeidel
Community Member
Make sure you are converting a 350AP, and not a bridge.
When using the conversion tool, make sure your vxworks is one of these: (if you have 12.04 you must downgrade)
12.03T, 12.02T1, 12.01T1, 12.00T, 11.23T, or 11.21
SNMP must be enabled.
You can get the conversion tool here:
http://www.cisco.com/public/sw-center/sw-wireless.shtml
