conversion
vijay kumar
Level 5
Level 5
We are converting 3600 ap from lwapp to autonomous . For conversion can we connect the AP and laptop to POE switch since no power card.
Whether this setup will work  for downloading the IOS from my tftp server. ?...
Scott Fella
That should work, but you would have to use the mode button to perform the conversion process since the other methods without a WLC would reboot the AP prior to you being able to convey the AP.
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
-Scott
Scott Fella
-Scott
