Converting a 9130 AP for wireless survey
nh6we
I am trying to setup my 9130AXE for wireless survey work.  In the past it was easy to setup the AP for autonomous mode and you were done.  Now with the 9130 I believe there are multiple steps.  I was able to convert my 9130 to run as a embedded wireless controller but it not broadcast anything my wireless survey software can use.  Can the 9130 act as a access point and a wireless controller at the same time?  If so, I have the wireless controller software working, how do get the AP side running.
Thanks for the help
Scott Fella
Just search the internet for Cisco EWC site survey and you will find a few. This will explain how to get a 91x0 AP configured for site survey.
https://www.google.com/amp/s/sc-wifi.com/2019/12/03/cisco-802-11ax-site-survey-single-ap-method/amp/
https://www.google.com/amp/s/howiwifi.com/2020/03/19/from-shelf-to-survey-cisco-9100ax-ewc-conversion/amp/
-Scott
