Cooperate SSID in HREAP mode and guest access in LWAPP design.
jojsanto
Hi all WIIRELESS GURUS!
Just a quick one, If default solution for guest access solution is for 2 SSID  (guest and cooperate) working in LWAPP mode. Is it possible use the cooperate  SSID in HREAP mode and guest access in LWAPP with EoIP from the central  controller to the anchor contoller?
Hope you can help.
Nicolas Darchis
yes
the APs have to be hreap but you only enable local switching for the corporate SSID and you link a mobiliy anchor to the guest ssid.
Nicolas Darchis
yes
