Core Switch DHCP Pool for Wireless - scope options for 9120AX
williamsonjason
Hello all, thanks for the quick advice if you can. It's been years since I've set up a pool. The basics are done - but what options do I need to point all my 9120AX APs to my new 9800 controller?
IP is 172.16.5.5 for the controller.
marce1000
           - Normally you will use DHCP Option 43 to let the APs discover the controller ,
 M.
