LAP1042 register to wrong controller
Ingénierie RCI
We facea problem with LAP1042N terminals, which suddenly try to register a bad controller after running normally.
They are on a 2500 controller and we have installed a C9800-CL to migrate to new access points on site.
The addition of new terminals is underway but will not be finalized for several months.
The C9800-CL controller is in version 17.6.4, it normally does not allow to use LAP1042Ns in this version.
The 2500 controller is in version 8.3.143.0.
Do you have any idea why the terminals are trying to reach the other controller? They have the IP of the 2500 registered.
I remain available for further testing or verification.
Thank you in advance
Regards.
Mark Elsen
 - It's not advisable to have two controller active in the same capwap broadcast domain (anyway)  ; for the time being isolate the C9800-CL , also have the APs using DHCP option 43 to find a controller  ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/97066-dhcp-option-43-00.html
As @Mark Elsen mention op43 is solution here.
Config op43 for LAP1042N different than other AP' and hence the dhcp server will send back different wlc IP for each AP.
MHM
Rich R
It sounds like you might have all your APs and WLCs together on the same broadcast domain (subnet/vlan) which means they will discover the new WLC via broadcast regardless of HA and option 43 settings?
This is why it's best practice to keep them separate and use option 43 for discovery.  Keep old and new APs on separate VLANs so that option 43 for old APs only points to old WLC and option 43 for new APs only points to the new WLC.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Leo Laohoo
1042 is not supported in 9800.
The last firmware 1140/1042 are supported is 8.4.X.X and 9800 will not support that version.
