CoS dscp marking on Cisco wirless controller
qyo001
Hi guys ,
Do you know if there is any way to mark some particular type of traffic with DSCP/ToS value , so the packet goes from wireless controller ( or access point) will have specific dscp ?
As an example - I want to have any HTTP packet coming from wireless users to wire to apply DSCP mark = cs2 .
As I see in Controllers ACL's we can use dscp as condition only , not as action.
Any suggestion will be apreciated
Thank you.
Scott Fella
The WLC and AP does not touch the DSCP markings at all. So to answer your question, no the WLC can't remark a packet.
-Scott
maldehne
Check this link as a reference :
http://www.cisco.com/en/US/partner/docs/solutions/Enterprise/Mobility/vowlan/41dg/vowlan_ch2.html#wp1046206
You cannot destinguish client traffic since it will be capwap encapsulated and the mapping will depend of the qos profile
configured for the WLAN profile at which the client is connected to as well as the dot11e tag in 802.11 frame sent by the client.
Please Don't Forget to rate correct answers
