web issue
senpay524
Community Member
We have Cisco AP's in our network. Here we have guest access to our network. We want to do next: when someone connected to our Ap with guest access and start browsing internet, every 15 minutes for example, our website should open in browser. How can we do this? Is it possible with AP or this should be done with proxy?
Please help.
thanks in advance.
Michael Burk
Level 3
Level 3
It is somewhat possible if you have a Cisco wireless controller.
You could setup 'Web Passthrough' on your guest network with a discliamer page that the user has to accept. You could have that re-direct to your website.
If you add a 15 minute timeout to your guest network in the WLAN > Advanced tab then you would have succesfully accomplished your goal.
The other, cleaner option would be the proxy server.
thanks Michael.
as i understand it's not possible without wireless controller
You would need a WLC or you might look at a third party guest portal software to do that.
-Scott
