08-15-2014 01:05 PM - edited 07-05-2021 01:22 AM
We have just implemented a 5508 controller pair with MSE, Prime, and ISE. The system is working well, but I keep getting the following message in the log of the controller:
[ERROR] apf_policy.c 3383: Could not apply interface override:
source Override Summation, interface '30', vlanId: 0x1e
Our APs are all set for FlexConnect so it seems to be reporting an issue applying the vlan override on an AP, but I have no reported issues of this not working. I cannot find this error anywhere in a reference guide. VLAN 30 is our local flexconnect user subnet.
2nd question regards the apf_policy.c 3383. Does this refer to a specific AP? If so is there some cross reference for this 3383 number to an actual AP in my system. I can't find any correlation. I've looked at MAC address, SN, etc.. and I don't see any correlation.
02-14-2015 05:36 AM
hi,
I am having the same error message on flex 7510 controllers as well.
Any ideas please, much appreciated
02-14-2015 06:19 AM
Might be a cosmetic bug to be honest if everything is working fine. You can open a TAC case so they can identify it as a bug or tell you if there is already a bud id.
-Scott
02-19-2015 09:38 PM
Vlan1d:0x1e i.e 30 , can you set no vlan override to vlan 30 in the
ISE and test if the error is thrown again
02-20-2015 02:14 AM
Saurav,
where in ISE can i make this change?
02-27-2015 10:03 AM
i think you better approach TAC to rectify the issue.
09-25-2025 05:58 AM
Make sure the vlan exist on the AP by either via WLAN VLAN mapping or ACL mapping. This guy explains it (https://www.youtube.com/watch?v=kO4GjFc2bQA)
Make sure the "Floxconnect Local Switching" is enabled on the WLAN -> Advanced -> Flexconnect.
