Create guest wifi at remote site with DID access
DAVID
Level 3
Level 3
I have multiple remote sites with Cisco 3700i access points in Flex-connect that are managed by a pair of 5520's running in the data center.  I'd like to setup a POC guest wifi network where the users on the guest-wifi get an IP address locally at the remote site from the Cisco C1100 router and are able to access the Internet locally at the site.
Rasika Nayanajith
You can create this new SSID with FlexConnect local switching enabled. That should allow you to locally terminate that traffic & give them direct internet access.
Rasika
*** Pls rate all useful responses ***
I think I know what I need to do but are there any  documentation examples that I can look at. In the end what I want to accomplish is that the guest will connect to the wireless at the store and  I use CMX Connect and Engage to provide guest services.
What I want to do first is to just provide simple Internet access with the access going out the local connection. Then I will follow up with a basic CMX engage setup
All of this is in a lab environment
