create high availability between cisco wireless controllers
almoosahospital
Community Member
Greetings,
i need to ask about what is the ability to create high availability between cisco wireless controllers physical and virtual
it's possabile or not
thanks
Mark Elsen
 - You can not dot HA SSO mode  and or limited to N+1 high availability , meaning that the list of available controllers is configured on the access points.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Scott Fella
Just to add, we don’t know what model or version you are running, but both should be on the same version. Please revive the N+1 guide.  this should help you understand what is required and how it should be setup.
https://www.cisco.com/c/en/us/td/docs/wireless/technology/hi_avail/N1_High_Availability_Deployment_Guide/N1_HA_Overview.html
-Scott
