CRL check WLC and AP
momo33
Is there an option to enable CRL check on an AP and controller running on 8.5?
I have LSC enabled and was able to issue certificates to both the AP and the controller with the CDP extension present in both but I don't see an attempt to fetch the CRL from any of them.
Thank you!
Rasika Nayanajith
I do not think so.
Rasika
Rasika Nayanajith
I do not think so.
Rasika
Hi Rasika,
Thank you for your response. it seems LSC does not support any revocation check at all.
Have a good weekend!
