CST: %CONTROLLER-5-UPDOWN:Controller E1 0/0/0,change state to down(AIS detected)
HI My friends; What is the meaning of these logs? Is there any potential problem? Is there any solution? CST:%CONTROLLER-5-UPDOWN:Controller E1 0/0/0,change state to up CST: %LINK-3-UPDOWN: Interface Serial0/0/0:0,change state to up CST: %LINEPROTO-5-UPDOWN:Line protocol on Interface Serial0/0/0:0.change state to up CST: %CONTROLLER-5-UPDOWN:Controller E1 0/0/0,change state to down(AIS detected)
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
I think this is a problem for ISP. Similar to alerts such as AIS and LOS, it seems to be a WAN problem. The factors related to the problem are equipment WAN interfaces, circuits,ISP' lines, etc.
 The CONTROLLER on the present log is not Wireless Lan Controller. This message came from, mostly probably, a Router running some voice gateway. The cause of it can be lost of sync with the service provider.
 By the way AIS stand for Alarm Indication Signal.
-If I helped you somehow, please, rate it as useful.-
Yes, this is not a wireless controller. It is an alarm on an ISR device. I suspect it is a problem with the ISP. This problem may be caused by what the operator does.
