CURWB 3500 Maximum Distance Settings
craigriebkes
In the advanced radio settings there is a maximum distance setting. Can someone tell me if there is a software defined maximum number and what that might be when in PTP mode?
The guide will at least show you the min and max values.
-Scott
5 Replies 5
Scott Fella
What exactly is the model?  Maximum distance for any PTP is how well you can achieve line of sight and the EIRP value.  Also the band the link will use can also determine that.
-Scott
It is what used to be the Fluid Mesh 3500 platform. I understand the EIRP and band ramifications. What I am trying to determine is there a maximum software defined value?
Sorry but not familiar with that model.  Have you looked at the configuration guide?
Cisco Ultra-Reliable Wireless Backhaul FM3500 Endo
-Scott
Thanks Scott. If I had access to a radio. I could look it up myself.
-Scott
